USRP Software Radio
Time synchronization of 2 USRP in Reception?
Hi,Smiley Happy
I did the MIMO synchronization of 2 USRP (the master is connected to the laptop via Ethernet cable and the slave is connected to the master via Mimo cable)
my script works good---> the attached file "pilotage2USRP.vi".
I set:  master--> RefIn and PpsIn     slave-->Mimo and Mimo
          master-->apply timestamp=Now     slave-->apply timestamp= NextTimebaseEdge
But the problem is that the signals recieved by the master and the slave don't begin in the same time despite the 2 cables that connect the master and the slave to the transmitter have the same lenght ?!
How i do to get to signals that begin in the same time?
Thank youSmiley Happy
(6,156 Views)
the script:
(6,155 Views)
Use "timed commands" to start the acquisition. There shipping examples and also full MIMO examples here: https://decibel.ni.com/content/groups/ni-usrp-example-labview-vis?view=documents
(6,148 Views)
thank you
but i have problems when i run these examples! I think is a path problem ?  all examples uploaded from NI website don't work on my laptop!!
(6,142 Views)
