07-29-2013 04:22 AM
Hi,![]()
I did the MIMO synchronization of 2 USRP (the master is connected to the laptop via Ethernet cable and the slave is connected to the master via Mimo cable)
my script works good---> the attached file "pilotage2USRP.vi".
I set: master--> RefIn and PpsIn slave-->Mimo and Mimo
master-->apply timestamp=Now slave-->apply timestamp= NextTimebaseEdge
But the problem is that the signals recieved by the master and the slave don't begin in the same time despite the 2 cables that connect the master and the slave to the transmitter have the same lenght ?!
How i do to get to signals that begin in the same time?
Thank you![]()
07-29-2013 04:24 AM
the script:
07-29-2013 06:44 AM
07-29-2013 08:42 AM
thank you
but i have problems when i run these examples! I think is a path problem ? all examples uploaded from NI website don't work on my laptop!!
