USRP Software Radio
Trying to get B200mini-i working on Ubuntu 20.04
Here is the output from lsusb:
jim@pop-os:~$ lsusb
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 002: ID 05e3:0625 Genesys Logic, Inc. USB3.2 Hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 020: ID 2500:0022 Ettus Research LLC USRP B205-mini
Bus 001 Device 011: ID 8087:0033 Intel Corp.
Bus 001 Device 007: ID 0db0:6c09 Micro Star International USB Audio
Bus 001 Device 010: ID 0db0:6a05 Micro Star International MEG Core Liquid S360
Bus 001 Device 009: ID 0db0:9ba6 Micro Star International USB HID
Bus 001 Device 005: ID 05e3:0608 Genesys Logic, Inc. Hub
Bus 001 Device 003: ID 1462:7d89 Micro Star International MYSTIC LIGHT
Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
See above, the device is recognized by the linux system (Ubuntu 22.04).  Hardware is Intel i9-13900k on a Z790 motherboard.
When I run und_find_devices I get this output:
jim@pop-os:~$ uhd_find_devices
[INFO] [UHD] linux; GNU C++ version 11.2.0; Boost_107400; UHD_4.1.0.5-3
[INFO] [B200] Loading firmware image: /usr/share/uhd/images/usrp_b200_fw.hex...
-- UHD Device 0
Device Address:
    serial: 3293561
    product: B205mini
    type: b200
So again it’s finding the device.
But when I run und_usrp_probe I get this output indicating that something is not right:
jim@pop-os:~$ uhd_usrp_probe
[INFO] [B200] Detected Device: B205mini
[INFO] [B200] Loading FPGA image: /usr/share/uhd/images/usrp_b205mini_fpga.bin...
[INFO] [B200] Operating over USB 3.
[ERROR] [UHD] Exception caught in safe-call.
  in virtual b200_radio_ctrl_core_impl::~b200_radio_ctrl_core_impl()
  at ./host/lib/usrp/b200/b200_radio_ctrl_core.cpp:66
this->peek32(0); _async_task.reset(); -> AssertionError: accum_timeout < _timeout
  in uint64_t b200_radio_ctrl_core_impl::wait_for_ack(bool)
  at ./host/lib/usrp/b200/b200_radio_ctrl_core.cpp:228
Error: AssertionError: accum_timeout < _timeout
(1,781 Views)
Is anyone at NI paying attention to customers?  Ghost town.
(1,759 Views)
We see the same error, with one of our B205 mini
1st B205 mini (working as reference)
$ uhd_usrp_probe
[INFO] [UHD] linux; GNU C++ version 11.3.0; Boost_107400; UHD_4.4.0.HEAD-0-g5fac246b
[INFO] [B200] Loading firmware image: /usr/local/share/uhd/images/usrp_b200_fw.hex...
[INFO] [B200] Loading FPGA image: /usr/local/share/uhd/images/usrp_b205mini_fpga.bin...
[INFO] [B200] Initialize CODEC control...
[INFO] [B200] Initialize Radio control...
[INFO] [B200] Performing register loopback test...
[INFO] [B200] Register loopback test passed
[INFO] [B200] Setting master clock rate selection to 'automatic'.
[INFO] [B200] Asking for clock rate 16.000000 MHz...
[INFO] [B200] Actually got clock rate 16.000000 MHz.
  _____________________________________________________
|       Device: B-Series Device
|   |       Mboard: B205mini
|   |   serial: 32B1728
|   |   name: B205i
|   |   product: 30522
|   |   revision: 6
|   |   FW Version: 8.0
|   |   FPGA Version: 7.0
|   |   Time sources:  none, internal, external
|   |   Clock sources: internal, external
|   |   Sensors: ref_locked
|   |     _____________________________________________________
|   |   |       RX DSP: 0
|   |   |   Freq range: -8.000 to 8.000 MHz
|   |   |       RX Dboard: A
|   |   |     _____________________________________________________
|   |   |   |       RX Frontend: A
|   |   |   |   Name: FE-RX1
|   |   |   |   Antennas: TX/RX, RX2
|   |   |   |   Sensors: temp, rssi, lo_locked
|   |   |   |   Freq range: 50.000 to 6000.000 MHz
|   |   |   |   Gain range PGA: 0.0 to 76.0 step 1.0 dB
|   |   |   |   Bandwidth range: 200000.0 to 56000000.0 step 0.0 Hz
|   |   |   |   Connection Type: IQ
|   |   |   |   Uses LO offset: No
|   |   |   |       RX Codec: A
|   |   |   |   Name: B205mini RX dual ADC
|   |   |   |   Gain Elements: None
|   |   |       TX DSP: 0
|   |   |       TX Dboard: A
|   |   |   |       TX Frontend: A
|   |   |   |   Name: FE-TX1
|   |   |   |   Sensors: temp, lo_locked
|   |   |   |   Gain range PGA: 0.0 to 89.8 step 0.2 dB
|   |   |   |       TX Codec: A
|   |   |   |   Name: B205mini TX dual DAC
2nd B205 mini (not working)
$ uhd_usrp_probe
  in ~b200_radio_ctrl_core_impl
  at /tmp/uhd/host/lib/usrp/b200/b200_radio_ctrl_core.cpp:65
  in wait_for_ack
  at /tmp/uhd/host/lib/usrp/b200/b200_radio_ctrl_core.cpp:227
  in wait_for_ack
(704 Views)
Is the error occurring on the same USB port of the host machine, or are the two duts plugged into different USB ports?
(696 Views)
