USRP Software Radio
USRP Config utility only sees USRP in safe mode, is there a way to recover the USRP?
USRP Config utility only sees usRP in safe mode, is there a way to recover the USRP?.
I have 2 USRP's one works perfectly the NI config utility sees it no problem.
The 2nd unit I think got corrupted. I reset the unit to safe mode and then reset the IP address to 192.168.10.3.
After rebooting the device the NI config utility no longer sees it. I have tried this several times.
And always after rebooting the USRP from safe mode the config utility no longer sees the USRP.
Any ideas how to fix this?
(1,976 Views)
I've been having the same problem since two months ago,
but no one in the community has replied...
I am also waiting for someone to respond.
(1,885 Views)
What device models and revisions are you using?  You can get this information by running
"C:\Program Files (x86)\National Instruments\NI-USRP\utilities\uhd_usrp_probe.exe"
(this path may differ slightly on your machine)
from the command line.  Please share the output here.
(1,875 Views)
Thank you for your answers.
The exe file you mentioned won't run.
In fact, other communities have asked me to run the same file and attach the code, but it doesn't work on my PC.
The execution screen disappears as soon as you click.
I'm using NI-USRP2921, 2932, unmanaged Ethernet switch hub of NETGEAR, and using gigabit Ethernet in Cat.5e as a cable.
The biggest problem is that even if an unmanaged Ethernet switch hub has multiple USRP connections, only one is recognized on the PC.
I'd appreciate it if you could come up with a solution.
(1,863 Views)
2025 same problem for USRP2920. configuration tool says it need an image&firmware update but even after the update it is impossible to reach USRP unless it is in safe mode.
(503 Views)
You can off a Windows Firewall.
(459 Views)
