USRP Software Radio
UHD examples Segmentation Fault
Hi all,
I'm having some problems trying to use the UHD examples.
Some of them I can use. However some of them give me a Segmentation Fault
rafael@rafael-Inspiron-7537:/usr/lib/uhd/examples$ ./tx_bursts --secs 5 --ampl 0.5 --freq 50e6
linux; GNU C++ version 4.8.2; Boost_105400; UHD_003.005.005-0-unknown
UHD Warning:
    Unable to set the thread priority. Performance may be negatively affected.
    Please see the general application notes in the manual for instructions.
    EnvironmentError: OSError: error in pthread_setschedparam
Creating the usrp device with: ...
-- Opening a USRP2/N-Series device...
-- Current recv frame size: 1472 bytes
-- Current send frame size: 1472 bytes
UHD Warning:
Segmentation fault (core dumped)
The same problem for examples like:
rx_timed_samples, test_timed_commands, tx_bursts, and others
I'm using:
-Ubuntu 14.04
-USRP n210
(6,892 Views)
Accepted by rafael.acurcio
Hi Rafael,
While you may find some other UHD users in these forums who can help the best bet is probably to send your question to support@ettus.com since they are much more experienced in UHD troubleshooting.
Best Regards,
Peter W.
RF PSE
(6,885 Views)
Hi Peter_W
I just did it, thanks for the tip.
(6,879 Views)
