USRP Software Radio
USRP 2901
I want to use USRP-2901, and I need information about minimum detectable Signal (minimum input signal). Which isn't explained in datasheets.
If someone knows about value of minimum detectable Signal of usrp2901
(1,551 Views)
NI USRP-2901 is OEM products from Ettus Research. B210 is original product name.
Did you check knowledge base about B210?
https://kb.ettus.com/B200/B210/B200mini/B205mini
(1,487 Views)
Yes,
But not explained about minimum detectable Signal
(1,471 Views)
Thank you,
Performed in lab.
By using good signal generator
CW 100MHz ,  minimum -120dbm,
(1,435 Views)
