USRP Software Radio
USRP 2932 connecting problem
When I'm connecting the USRP-2932 to my PC, my PC can not find it all the time.
I have closed the firewall before. And neither windows 10 and ubuntu17.04 can find the device.
I used NI-USRP Configuration Utility on windows 10. On ubuntu, I have install the latest version UHD before.
Because my PC do not has ethernet port, so I used an adapter that transform the USB2.0 to Fast Ethernet.
What should I do to solve the connection problem?
I'll very appreciate it if you give me the advice after reading!
(4,165 Views)
Did you download the latest driver for NI-USRP?
http://www.ni.com/en-us/support/downloads/drivers/download.ni-usrp.html
(4,148 Views)
Yes,I did.
I have downloaded the NI-USRP 18.5 before. But the configuration utility still can not find the device after I connect it to PC.
(4,145 Views)
Were you able to detect it previously?
Here's a guide to help you get started : http://www.ni.com/pdf/manuals/376356a.pdf
This forum post might be useful:
https://forums.ni.com/t5/USRP-Software-Radio/Problem-connecting-USRP-2920-to-Windows10-and-Realtek-P...
(4,141 Views)
It was never detected before. And after I connected it to PC, I found problem like this(blue area),promot the Network cable unplugged:
 And my USB2.0 to Fast Ethernet Adapter only supprot 100 Mbps. Is that cause the problem?
(4,130 Views)
Accepted by guozi
Hi Guozi,
Yes, you're right. I checked the Read Me of NI-USRP 18.5 and the USRP 2932 is not compatible with USB 2.0
http://www.ni.com/pdf/manuals/374760t.html
 *I think there's a typo, it should be 2932 and not 3932. NI does not have USRP- 3932
(4,126 Views)
Thanks!
I'll try after I get the new adapter.
(4,124 Views)
