USRP Software Radio
USRP 2944 Ethernet reset IP from 169.254.x.x to default 192.168.10.2
   How to reset the IP of USRP 2944 to default IP 192.168.10.2. I do not see the (S2) as suggested in
https://www.ni.com/docs/en-US/bundle/usrp-292x-getting-started/page/why-doesnt-device-ip-address-res...
    I do see Switch SW1 and SW3 but I do not see SW2 or (S2). I need this switch to update the default IP of the USRP to 192.168.10.2 USRP_2944_missing_S2.jpg
    Please suggest if there is another way to update the USRP 2944 IP to 192.168.10.2
    Thank you
(1,722 Views)
Additional information from the terminal:: I am not able to udate/reset the IP of USRP 2944 back to default 192.168.10.2
% ifconfig
lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> mtu 16384
	options=1203<RXCSUM,TXCSUM,TXSTATUS,SW_TIMESTAMP>
	inet 127.0.0.1 netmask 0xff000000
	inet6 ::1 prefixlen 128
	inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
	nd6 options=201<PERFORMNUD,DAD>
gif0: flags=8010<POINTOPOINT,MULTICAST> mtu 1280
stf0: flags=0<> mtu 1280
en0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
	options=50b<RXCSUM,TXCSUM,VLAN_HWTAGGING,AV,CHANNEL_IO>
	ether ac:87:a3:3b:e6:73
	inet6 fe80::149a:4d66:d5e5:9c20%en0 prefixlen 64 secured scopeid 0x4
	inet 169.254.70.83 netmask 0xffff0000 broadcast 169.254.255.255
	media: autoselect (1000baseT <full-duplex>)
	status: active
en1: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
	options=400<CHANNEL_IO>
	ether d0:a6:37:e7:72:84
	inet6 fe80::cec:7ca8:776b:1c7a%en1 prefixlen 64 secured scopeid 0x5
	inet 192.168.0.190 netmask 0xffffff00 broadcast 192.168.0.255
	media: autoselect
	status: active
en2: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
	options=460<TSO4,TSO6,CHANNEL_IO>
	ether 82:0a:56:35:8d:00
	media: autoselect <full-duplex>
	status: inactive
% ping -b en1 -c 5 192.168.0.255
PING 192.168.0.255 (192.168.0.255): 56 data bytes
64 bytes from 192.168.0.190: icmp_seq=0 ttl=64 time=0.137 ms
64 bytes from 192.168.0.142: icmp_seq=0 ttl=32 time=96.822 ms
64 bytes from 192.168.0.190: icmp_seq=1 ttl=64 time=0.127 ms
64 bytes from 192.168.0.142: icmp_seq=1 ttl=32 time=18.714 ms
64 bytes from 192.168.0.190: icmp_seq=2 ttl=64 time=0.115 ms
64 bytes from 192.168.0.142: icmp_seq=2 ttl=32 time=39.038 ms
64 bytes from 192.168.0.190: icmp_seq=3 ttl=64 time=0.101 ms
64 bytes from 192.168.0.142: icmp_seq=3 ttl=32 time=57.985 ms
64 bytes from 192.168.0.190: icmp_seq=4 ttl=64 time=0.150 ms
--- 192.168.0.255 ping statistics ---
5 packets transmitted, 5 packets received, +4 duplicates, 0.0% packet loss
round-trip min/avg/max/stddev = 0.101/23.688/96.822/32.594 ms
(1,686 Views)
