USRP Software Radio
USRP 2944R reading Channel 0 and 1 of the same RF end at the same time
Hi!
I have USRP-2944R and I want to use channel 0 and 1 of same RF end either RF0 or RF1 as a receiver. I am working on USRP simple streaming project. Can someone guide me what and where changes are required there to achieve my goal. To verify this I can use Tx of other RF end and loop back it to both channels of same RF end.
(131 Views)
Hello qureshi000,
To help you get started using the USRP-2944 with LabVIEW follow the next link to have examples, lessons and samples: NI-USRP Examples, Lessons, and Sample Projects
Once you can control the device follow the next steps to test if both channels work simultaneously:
  • Fix RF0/1 for transmission.
  • Loop back the signal to RF1 RX1 and RX0 (or RF0 RX0 and RX1).
  • Verify if the signals are correctly read by both channels.
Have a good day,
Hugo
(57 Views)
