USRP Software Radio
USRP RIO as a access point(AP) using 802.11 application framework
Can i know how can i use USRP RIO as an access point(AP) using 802.11 application framework.
(3,992 Views)
The 802.11 app framework is standards-based but not fully standard compliant.  This has many advantages. However connecting a commercial wireless device is not supported.  A full stack would be required for such an activity.  The intended use case is to use 2 or more usrp devies as both ends of the link, your UE and AP.
erik
(3,984 Views)
Hi Erik,
Thanks for your reply. May i  know what are the changes need to be done to the existing 802.11 appl. framework to build a complete stack and to make it work as an access point.
(3,938 Views)
