USRP Software Radio
Usrp2920 with other RF module
Can you recommend me to use other RF module ex. Apc220 module with USRP2920 (max2.2GHz) . I try to use APC220 with USRP but APC220 datasheet doesn't have details about protocol such as packet, frequency start-stop,synchronized etc.
(4,121 Views)
Hello OATelecom,
Are you referring to the Apc 220 device that is used with Arduino boards?  Any transmitter/receiver that follows a known protocol will work.  Can I ask what your end goal is?
John R
John R.
(4,088 Views)
Hello John
I refer to use apc220 (RF module ) for Transmitter on raspberrypi board and use Usrp2920 for Receiver on computer .So I want to known this two device can communicate between
Thank you
(4,079 Views)
As long as you are sending a signal from your transmitter, the receiver should be able to set it.  You will want to make sure you are operating at the same frequency and amplitude.  I would also confirm you have the correct size antennas and the IQ rate set accordingly.  Are you using one of the USRP LabVIEW examples?
John
John R.
(4,065 Views)
