USRP Software Radio
USRP X410 connection with 100Gb/s speed problem
Hello everyone,
I’m currently working on a Linux Ubuntu 24.04 system and using a USRP X410. I’d like to use a QSFP-100G-AC01 (100 G QSFP28 ACU) cable to connect my computer to the X410. By default, I’m able to achieve a 10 Gb/s transmission speed, but I’d like to configure the setup to use 100 Gb/s instead.
The attached files show the results of our 10 Gb/s tests, and now we’re trying to force the connection to operate at 100 Gb/s.
We also performed a loopback test on our computer using the two ports of the ConnectX-5 EN network interface card (ConnectX-5 100 GbE MCX516A-CCAT). In that configuration, each port showed a link speed of 50 Gb/s, as expected.
However, when we connect the cable to the X410 (QSFP28 port 0), the LED for port 0 blinks, but port 1 does not show any activity.
Could anyone please advise whether there’s something that needs to be activated or configured on the X410 to enable 100 Gb/s operation? Or is there an additional step I might be missing?
Thank you for your help!
Yang
(155 Views)
Accepted by topic author MikeYang
the available streaming interface on the USRP X410 is determined by the loaded FPGA image. By default this is the X4_200 image providing 4x10GbE link on sfp0 only, sfp1 is not used by this FPGA image. To use a 100GbE interface you need to use the CG_400 or UC_200 image. Please https://uhd.readthedocs.io/en/latest/page_usrp_x4xx.html#x4xx_updating_fpga for details on the precompiled FPGA images available with UHD and how to update the FPGA image.
Regards
(146 Views)
Thank you very much for your reply. Yes, after using the correct CG_400 image, we were able to achieve a 100Gb/s connection, which was precisely the point cause of our previous issues.
Best Regards
(109 Views)
