11-12-2013 07:39 AM
Hi All,
two usrp are connected with MIMO cable and it is shared ethernet mode.
I already set the clock source for the master usrp a defult and the slave usrp uses MIMO cable.
the same with time source.
However when i transmit the samples only one usrp is transmitting, the other usrp is not transmittig at all.
= tx_stream_->send( buffer, samples_ptr_->vector_[0].size(), tx_md_, uhd_sample_timeout_ );
Please give me some hints,
DEE
Solved! Go to Solution.
11-12-2013 09:56 AM - edited 11-12-2013 09:56 AM
Are you using LabVIEW? This forum is mostly focused on LabVIEW with USRP.
Supprt for UHD and GNU Radio are all provided by the open source community.
(UHD specific help may be available at support@ettus.com )
If you are using LabVIEW, this document may be helpful:
http://www.ni.com/white-paper/14311/en/
