USRP Software Radio
USRP x300 Error: timed out waiting for consecutive locks on sensor "lo_locked"
Hello everyone,
I got an usrp x300,  using a UHD command  "rx_samples_to_file "  to capture RF sample. The x300 worked normally many times, but now I get this error on  RX2 port of both RF A and RF B channels:
     Waiting for "lo_locked":_______
I mainly use RF A channel on the x300 , when the error appeared, I changed  to the RF B channel,  it worked fine at first but then also got the same error.
Is there anyone got the same error or has solution for this problem, please advice.
Thank you in advance
Message 1 of 1
(1,672 Views)
