USRP Software Radio
Using the USRP-2943 with GNU Radio
From looking at some other posts on this forum, it seems to be the case that using the USRP-2943 (along with other NI-branded USRPs) with GNU radio requires flashing the FPGA with the relevant image from Ettus UHD. In the case of the USRP-2943, that would be the image for the X310.
Once this is done, is it possible to flash the FPGA back to LabView compatibility with the NI-USRP image? Or is this a one-way process which essentially results with an Ettus X310 in an NI-branded case?
The Ettus X310 requires flashing the FPGA via the JTAG interface. Is the same true for the USRP-2943?
Thanks very much for your help!
Message 1 of 1
(1,495 Views)
