USRP Software Radio
When maximizing the IQ rate results non-synchronized TX-RX
I'm experimenting with the LabVIEW Comms 2.0 project entitled "USRP RIO 120-160 MHz BW Single-Device Streaming".. My problem is when I try to use the maximum IQ rate 120Mhz, the RX signal seems non synchronized with the TX waveform. It only synchronizes when I use below 50Mhz IQ rate. Can someone explain to me why? Also, is this possible to overcome?
I'm using USRP 2940R.
(2,375 Views)
What synchronization are you referring to? Could you show us pictures of the 120M and 50M rates for comparison as well as all other front panel connections and wiring?
Chase
NI Technical Support Engineer
(2,345 Views)
