USRP Software Radio
binary GPS data for VI-example RF Record and Playback with NI USRP
In the demo video, a ublox was used to record the GPS signal while driving. How is it possible to record with u-center in a binary data format which is useable inside LabView for playing back the GPS signal? Ublox uses the *.ubx data format, is there a converter?
(8,101 Views)
Hi, I´m sorry, but at the very first I have to state that I cannot see any video at the link you´ve provided.
Anyway, it is the right document to get started with RF-Recording/Playback with the NI-USRP.
The USRP has a LabVIEW driver, so you don´t have to worry about file formats, you get the data as IQ-Clusters or arrays or whatever LabVIEW-datatype and
you can save it in your own binary format or with LabVIEW-provided functions, TDMS for instance.
If you want to import a certain binary file format into LabVIEW, you gotta have all the details about the header and dataformat of the file format.
Then, you can do a binary read, and interpret the data with the knowledge mentioned above.
If you don´t have this information, no chance.
There´s also a site where we host so called dataplugins for a number of common file-formats. https://www.ni.com/en/support/downloads/dataplugins.html
But I couldn´t find *.ubx there. So I guess you will have to implement it yourself.
Marco Brauner NIG
(8,084 Views)
I guess you using some scriptblock plugin in your browser. You have to allow scripts from tesla.ni.com, then there is a video under the mentioned link. I already wrote ErikL a private message, but he has not answered yet.
(8,026 Views)
Accepted by YYYs
Hello YYYs,
The file was not generated by uBlox, but by the record and playback VI.  An active GPS antenna, powered by some mini-circuits amplifiers, was connected to the USRP and the LabVIEW program created the file (USRP being used as a receiver)
Later the USRP is replaying the file (generating) and the Ublox GPS receiver is being fooled into thinking it's location is currently somewhere else.
Anthony F.
Staff Software Engineer
(8,009 Views)
