USRP Software Radio
how to use dsp logic in b205mini fpga
hello,
i'm using the usrp b205mini , in my project i need to add into the fabric of the fpga some dsp algorithms .
according to this manual https://files.ettus.com/manual/md_fpga.html my usrp sdr belong to  generation3 .
after building the ISE project for the b205mini i tried to use both fft ver7.1 and fft ver8.0 LOGIC CORE IP of xiliinx but i got stuck with the main problem that is that i don't know what is the signal chain here. for generation 2 you explain that  we can add dsp modules after/before the ddc and duc modules but now i can't find in this vast hierarchy any modules like them and i don't know where i can connect my fft in your project.
i will appreciate if you explain me the signal chain in the fpga and how you edit it via the ISE .
i will add in here the top module of the b205mini with instasiation of the fft ver8 module which is not finished to lack of knowledge about the right connections.
with best regards.
Dror
// Copyright 2015 Ettus Research, a National Instruments Company
// SPDX-License-Identifier: LGPL-3.0-or-later
 * B205 Module Declaration
module b205 (
   // AD9364 - SPI Interface:
   output CAT_SPI_EN,   // Enable
   input CAT_SPI_DO,   // MISO
   output CAT_SPI_DI,   // MOSI
   output CAT_SPI_CLK,  // SPI Clk
   // AD9364 - Control:
   output CAT_EN,
   output CAT_EN_AGC,
   output CAT_RESETn,
   output CAT_TXnRX,
   output [3:0]  CAT_CTL_IN,  // These should be outputs
   input [7:0] CAT_CTL_OUT, // MUST BE INPUT
   // AD9364 - Data:
   input CAT_DCLK_P,  // Clock from AD9364 (RX)
   output CAT_FBCLK_P, // Clock to AD9364 (TX)
   output    CAT_FBCLK_N,
   input [11:0]  CAT_P0_D,  // RX data is on Port 0
   output [11:0] CAT_P1_D,  // TX data is on Port 1
   input CAT_RX_FR_P,
   output CAT_TX_FR_P,
   output    CAT_TX_FR_N,
   // AD9364 - Always on 40MHz clock:
   input CLK_40MHz_FPGA,
   // GPIF, FX3 Slave FIFO
   output FX3_PCLK,  // pclk
   output FX3_CTL0,  // n_slcs
   output FX3_CTL1,  // n_slwr
   output FX3_CTL2,  // n_sloe
   output FX3_CTL3,  // n_slrd
   output FX3_CTL7,  // n_pktend
   input FX3_CTL4,  // slfifo_flags[0]
   input FX3_CTL5,  // slfifo_flags[1]
   input FX3_CTL6,  // Serial settings bus from FX3. SDA
   input FX3_CTL8,  // Serial settings bus from FX3. SCL
   output FX3_CTL11, // slfifo_addr[1]
   output FX3_CTL12, // slfifo_addr[0]
   inout [31:0]  FX3_DQ,
   input FX3_CTL9, // global_reset
   // LEDs
   output        cLED_TRX_G,
   output        cLED_TRX_B,
   output        cLED_TRX_R,
   output        cLED_RX2_G,
   output        cLED_RX2_B,
   output        cLED_RX2_R,
   output        cLED_S0,
   output        cLED_S1,
   // GPIO
   inout [7:0] fp_gpio,
   // PPS or 10 MHz (need to choose from SW)
   input         PPS_IN,
   input         CLKIN_10MHz,
   output        CLKIN_10MHz_REQ,
   // Clock disciplining / AD5662 controls
   output        CLK_40M_DAC_nSYNC,
   output        CLK_40M_DAC_SCLK,
   output        CLK_40M_DAC_DIN,
   // RF Hardware Control
   output        cFE_SEL_TRX_TX, // Select TX/RX port for Tx
   output        cFE_SEL_TRX_RX, // Select TX/RX port for Rx
   output        cFE_SEL_RX_TRX, // Select TX/RX port for Rx
   output        cFE_SEL_RX_RX2, // Select RX2 port for Rx
   output        cTXDRV_PWEN     // Tx PA enable
    wire reset_global = FX3_CTL9;
    // generate clocks from always on codec main clk
    wire bus_clk, radio_clk;
    wire locked;
    wire int_40mhz;
    wire ref_pll_clk;
    b205_clk_gen gen_clks
        .CLK_IN1_40(CLK_40MHz_FPGA), // No differential input!
        .CLK_OUT1_40_int(int_40mhz), .CLK_OUT2_100_bus(bus_clk), .CLK_OUT3_200_ref_pll(ref_pll_clk),
        .RESET(reset_global), .LOCKED(locked)
    //hold-off logic for clocks ready
    reg [15:0] clocks_ready_count;
    reg clocks_ready;
    always @(posedge bus_clk or posedge reset_global or negedge locked) begin
        if (reset_global | !locked) begin
            clocks_ready_count <= 16'b0;
            clocks_ready <= 1'b0;
        end
        else if (!clocks_ready) begin
            clocks_ready_count <= clocks_ready_count + 1'b1;
            clocks_ready <= (clocks_ready_count == 16'hffff);
        end
    end
    // drive output clocks
    ODDR2 #(
        .DDR_ALIGNMENT("NONE"), // to "NONE", "C0" or "C1"
        .INIT(1'b0),            // output to 1'b0 or 1'b1
        .SRTYPE("ASYNC")        // set/reset "SYNC" or "ASYNC"
    ODDR2_S6CLK2PIN
        .Q(FX3_PCLK),   // 1-bit DDR output data
        .C0(bus_clk),  // 1-bit clock input
        .C1(~bus_clk), // 1-bit clock input
        .CE(1'b1),      // 1-bit clock enable input
        .D0(1'b1),      // 1-bit data input (associated with C0)
        .D1(1'b0),      // 1-bit data input (associated with C1)
        .R(1'b0),       // 1-bit reset input
        .S(1'b0)        // 1-bit set input
    // Create sync reset signals
    wire bus_rst, ref_pll_rst, radio_rst;
    reset_sync bus_sync(.clk(bus_clk), .reset_in(!clocks_ready), .reset_out(bus_rst));
    reset_sync ref_pll_sync(.clk(ref_pll_clk), .reset_in(!clocks_ready), .reset_out(ref_pll_rst));
    reset_sync radio_sync(.clk(radio_clk), .reset_in(!clocks_ready), .reset_out(radio_rst));
    // reference clock PLL
    wire ref_sel;
    wire ext_ref_is_pps;
    wire ext_ref_locked;
    wire ext_ref = ext_ref_is_pps ? PPS_IN : ref_sel ? CLKIN_10MHz : 1'b0;
    b205_ref_pll ref_pll
        .reset(ref_pll_rst),
        .clk(ref_pll_clk),
        .refclk(int_40mhz),
        .ref(ext_ref),
        .locked(ext_ref_locked),
        .sclk(CLK_40M_DAC_SCLK),
        .mosi(CLK_40M_DAC_DIN),
        .sync_n(CLK_40M_DAC_nSYNC)
    assign CLKIN_10MHz_REQ = ref_sel;
   // AD9364 I/O
   wire [31:0] rx_data;
   wire [31:0] tx_data;
   b205_io b205_io_i0
      .reset(reset_global),
      // Baseband sample interface
      .radio_clk(radio_clk),
      .rx_i0(rx_data[31:20]),
      .rx_q0(rx_data[15:4]),
      .tx_i0(tx_data[31:20]),
      .tx_q0(tx_data[15:4]),
       // Catalina interface
      .rx_clk(CAT_DCLK_P),
      .rx_frame(CAT_RX_FR_P),
      .rx_data(CAT_P0_D),
      .tx_clk(CAT_FBCLK_P),
      .tx_frame(CAT_TX_FR_P),
      .tx_data(CAT_P1_D)
   assign {rx_data[19:16],rx_data[3:0]} = 8'h0;
   assign CAT_FBCLK_N = 1'b0;
   assign CAT_TX_FR_N = 1'b0;
   // SPI connections
   wire mosi,  miso, sclk;
   wire [7:0]  sen;
   // AD9364 Slave (it's the only slave for B205)
   assign CAT_SPI_EN   =  sen[0];
   assign CAT_SPI_DI   = ~sen[0] & mosi;
   assign CAT_SPI_CLK  = ~sen[0] & sclk;
   assign miso         = CAT_SPI_DO;
    // bus signals
    wire [63:0] ctrl_tdata, resp_tdata, rx_tdata, tx_tdata;
    wire ctrl_tlast, resp_tlast, rx_tlast, tx_tlast;
    wire ctrl_tvalid, resp_tvalid, rx_tvalid, tx_tvalid;
    wire ctrl_tready, resp_tready, rx_tready, tx_tready;
    // frontend assignments
    wire [7:0] fe_gpio_out;
    reg [7:0] fe_gpio_reg;
    //Register in IOB
    always @(posedge radio_clk)
      fe_gpio_reg <= fe_gpio_out;
    assign {cTXDRV_PWEN, cFE_SEL_RX_RX2, cFE_SEL_TRX_TX, cFE_SEL_RX_TRX, cFE_SEL_TRX_RX} = fe_gpio_reg[7:3];
    assign cLED_TRX_R = ~fe_gpio_reg[0];
    assign cLED_TRX_G = ~fe_gpio_reg[1];
    assign cLED_TRX_B = 1'b1;
    assign cLED_RX2_R = 1'b1;
    assign cLED_RX2_G = ~fe_gpio_reg[2];
    assign cLED_RX2_B = 1'b1;
    assign cLED_S0 = ~ext_ref_locked;
    assign cLED_S1 = ~(ext_ref);
    wire [31:0] misc_outs;
    reg [31:0] misc_outs_r;
    always @(posedge bus_clk) misc_outs_r <= misc_outs; //register misc ios to ease routing to flop
    assign ref_sel = misc_outs_r[0];
    wire codec_arst = misc_outs_r[2];
    assign CAT_CTL_IN = 4'b1;
    assign CAT_EN_AGC = 1'b1;
    assign CAT_TXnRX  = 1'b1;
    assign CAT_EN     = 1'b1;
    assign CAT_RESETn = ~codec_arst;   // Codec Reset // RESETB // Operates active-low
    // b205 core
    wire [7:0] fp_gpio_in, fp_gpio_out, fp_gpio_ddr;
    b205_core #(.EXTRA_BUFF_SIZE(12)) b205_core
        .bus_clk(bus_clk), .bus_rst(bus_rst),
        .tx_tdata(tx_tdata), .tx_tlast(tx_tlast), .tx_tvalid(tx_tvalid), .tx_tready(tx_tready),
        .rx_tdata(rx_tdata), .rx_tlast(rx_tlast),  .rx_tvalid(rx_tvalid), .rx_tready(rx_tready),
        .ctrl_tdata(ctrl_tdata), .ctrl_tlast(ctrl_tlast),  .ctrl_tvalid(ctrl_tvalid), .ctrl_tready(ctrl_tready),
        .resp_tdata(resp_tdata), .resp_tlast(resp_tlast),  .resp_tvalid(resp_tvalid), .resp_tready(resp_tready),
        .radio_clk(radio_clk), .radio_rst(radio_rst),
        .rx0(rx_data),
        .tx0(tx_data),
        .fe_gpio_out(fe_gpio_out),
        .fp_gpio_in(fp_gpio_in), .fp_gpio_out(fp_gpio_out), .fp_gpio_ddr(fp_gpio_ddr),
        .ext_ref_is_pps(ext_ref_is_pps),
        .pps_ext(PPS_IN),
        .sclk(sclk), .sen(sen), .mosi(mosi), .miso(miso),
        .rb_misc({31'b0,ext_ref_locked}), .misc_outs(misc_outs),
        .lock_signals(CAT_CTL_OUT[7:6]),
        .debug()
    gpio_atr_io #(.WIDTH(8)) gpio_atr_io_inst (
        .clk(radio_clk), .gpio_pins(fp_gpio),
        .gpio_ddr(fp_gpio_ddr), .gpio_out(fp_gpio_out), .gpio_in(fp_gpio_in)
wire [31:0] fft_output;
reg [7:0] s_axis_config_tdata =8'b00000001;
fft_axi fft_8192 (
  .aclk(bus_clk), // input aclk
  .s_axis_config_tdata(s_axis_config_tdata), // input [7 : 0] s_axis_config_tdata
  .s_axis_config_tvalid(1'b1), // input s_axis_config_tvalid
  .s_axis_config_tready(), // output s_axis_config_tready
  .s_axis_data_tdata(rx_tdata), // input [31 : 0] s_axis_data_tdata from b205_core
  .s_axis_data_tvalid(rx_tvalid), // input s_axis_data_tvalid from b205_core
  .s_axis_data_tready(rx_tready), // output s_axis_data_tready to b205_core
  .s_axis_data_tlast(rx_tlast), // input s_axis_data_tlast from b205_core
  .m_axis_data_tdata(m_axis_data_tdata), // output [31 : 0] m_axis_data_tdata
  .m_axis_data_tuser(m_axis_data_tuser), // output [7 : 0] m_axis_data_tuser
  .m_axis_data_tvalid(m_axis_data_tvalid), // output m_axis_data_tvalid
  .m_axis_data_tlast(m_axis_data_tlast), // output m_axis_data_tlast
  .m_axis_status_tdata(m_axis_status_tdata), // output [7 : 0] m_axis_status_tdata
  .m_axis_status_tvalid(m_axis_status_tvalid), // output m_axis_status_tvalid
  .event_frame_started(event_frame_started), // output event_frame_started
  .event_tlast_unexpected(event_tlast_unexpected), // output event_tlast_unexpected
  .event_tlast_missing(event_tlast_missing), // output event_tlast_missing
  .event_data_in_channel_halt(event_data_in_channel_halt) // output event_data_in_channel_halt
    // GPIF2
    gpif2_slave_fifo32 #(.DATA_RX_FIFO_SIZE(13), .DATA_TX_FIFO_SIZE(13)) slave_fifo32
        .gpif_clk(bus_clk), .gpif_rst(bus_rst), .gpif_enb(1'b1),
        .gpif_ctl({FX3_CTL8, FX3_CTL6, FX3_CTL5, FX3_CTL4}), .fifoadr({FX3_CTL11, FX3_CTL12}),
        .slwr(FX3_CTL1), .sloe(FX3_CTL2), .slcs(FX3_CTL0), .slrd(FX3_CTL3), .pktend(FX3_CTL7),
        .gpif_d(FX3_DQ),
        .fifo_clk(bus_clk), .fifo_rst(bus_rst),
        .debug()
endmodule // B205
Message 1 of 1
(839 Views)
