USRP Software Radio
"MIMO Cable link did not lock within alloted time" error in USRP 2922
I am running Prof Heath courseware experiments, specifically lab 2.1, on USRP 2922 and I have come through this error:
"niUSRP Initiate.vi<ERR>The MIMO cable link did not lock within the alloted time." with error code "-1074118624". I don't understand the error and don't know what to do noting that I'm not using anything related to MIMO and I don't have a MIMO cable in the first place.
Can someone help me with that? Thanks!
Message 1 of 18
(7,782 Views)
Can you tell me a bit more about your hardware and software set up? At what point in your program do you receive this error?
Message 2 of 18
(7,758 Views)
I'm using the NI USRP-2922 box with ethernet connection to the computer. The software used is LabView 2013 with Service Pack 1, and NI-USRP Software Suite 1.2. The VIs I'm using are those provided by Dr Heath among his courseware for the wireless communications lab, specifically Lab 2.1, top_rx.vi. It stops working from the very start: when I run the vi (after running top_tx.vi on another machine with another USRP and wait till the green light goes on) it reports this error and stops.
Message 3 of 18
(7,755 Views)
Are you able to use highlight execution to locate the VI that is throwing this error?
Message 4 of 18
(7,742 Views)
I did and found that "niUSRP Initiate.vi" is the block that gives this error. It's located in the subvi "RXRF_recv.vi" which is used in the main vi "top_rx.vi". I also made sure that the input to this block is teh correct IP address and that error in is OK.
Message 5 of 18
(7,737 Views)
Have you been able to run any examples with your current hardware? If this code has worked before, was there any identifiable change that may have caused this error?
If you have a screenshot of the configuration portion leading up to the portion of your code that throws this error that would also be helpful.
Message 6 of 18
(7,721 Views)
Here I am attaching screenshots for the top_rx.vi (1.jpg and 2.jpg) showing the hardware parameters and the modulation parameters respectively and a screenshot for the receiver.vi (the subvi, 3.jpg) where the problem occurs.
And yes, I've been able to run other examples: the vi for the first experiment ran smoothly.
Message 7 of 18
(7,717 Views)
Accepted by mado0101
One possible case where you could get the "MIMO cable link did not lock..." error is if you set the reference frequency source to "Mimo" mode and were not actually using any mimo cables or configuration.
Message 8 of 18
(7,710 Views)
Thank you. It worked. Though it's strange since it's stated in the help that "internal" is the default value for the frequency reference clock, though I had to enforce it using the property node to remove this "MIMO error"!
Thanks again for your help.
Best,
Ahmed
Message 9 of 18
(7,705 Views)
Hi Ahmed,
I am glad that it worked.
Message 10 of 18
(7,667 Views)
