USRP Software Radio
radio station document
Hi.
I would like to build a radio station which is able to receive and transmit the FM signal with USRP 2920 and LabView
I already look up some example, but quite still dont understand how does it work?
Need some document to understand more ?
Thanks much.
(5,814 Views)
Hello -
Recieving FM Radio is possible using the following example:
https://decibel.ni.com/content/docs/DOC-23110
An example of FM modulation is done here:
https://decibel.ni.com/content/docs/DOC-25893
This is a great way to learn.  We recomend not transmitting over the air unless you have the proper license.
Erik
(5,801 Views)
Thanks much
(5,785 Views)
