07-23-2013 05:58 PM
Hi.
I would like to build a radio station which is able to receive and transmit the FM signal with USRP 2920 and LabView
I already look up some example, but quite still dont understand how does it work?
Need some document to understand more ?
Thanks much.
07-23-2013 10:42 PM
Hello -
Recieving FM Radio is possible using the following example:
https://decibel.ni.com/content/docs/DOC-23110
An example of FM modulation is done here:
https://decibel.ni.com/content/docs/DOC-25893
This is a great way to learn. We recomend not transmitting over the air unless you have the proper license.
Erik
07-24-2013 09:45 PM
Thanks much
