USRP Software Radio
usrp 2901 with gnuradio
I want to use NI USRP 2901 with gnuradio.
I have searched  and I found that I need to update the FPGA image and firmware.
I found these instructions for the NI 292X
http://digital.ni.com/public.nsf/allkb/F622E3B3B9CC34B6862579D500705272
What are the equivalent instructions for the NI 2901 (connected using USB not ethernet)?
Where can I obtain the FPGA image and firmware?
Message 1 of 13
(10,517 Views)
First, have you confirmed the USRP 2901 USB Connection in the USRP Configuration Utility?  You can take a look starting on page 6 of the 'Getting Started Guide' of the USRP 2901:
http://www.ni.com/pdf/manuals/376357a.pdf
Jonathan R.
Message 2 of 13
(10,499 Views)
Yes. I have done that.
I connected it and it shows up there.
Message 3 of 13
(10,493 Views)
Hello samer1,
There are several threads in the past talking about using the USRP with GNU Radio. Please take a look at these threads and see if Sarah Y provided enough information about the FPGA images and firmware for you to get started.
http://forums.ni.com/t5/USRP-Software-Radio/Can-NI-USRP-be-worked-on-GNU-Radio/td-p/1902375
https://forums.ni.com/t5/USRP-Software-Radio/Question-about-GNU-Radio/td-p/2461686
Message 4 of 13
(10,479 Views)
Accepted by samer1
It turned out that the UHD version I had was old, I updated my UHD version to the latest. It automatically loaded the correct FPGA image and firmware. Now it i is working fine with gnuradio.
Thanks.
Message 5 of 13
(10,425 Views)
You're welcome!
Message 6 of 13
(10,002 Views)
If I would like to use USRP-2901 with GNU Radio, could you help to tell me if I need to write image for USRP-2901 in NI-USRP Configuration Utility. And which firmware can I choose for USRP-2901?
Yingying
Message 7 of 13
(9,285 Views)
You should only install a new version of UHD. The first time you try to use the USRP, UHD will automatically load the FPGA image and firmware.
I did not use NI-USRP Configuration Utility.
Message 8 of 13
(9,282 Views)
Thank you so much. I will update to UHD 3.9.4.
Message 9 of 13
(9,280 Views)
You are welcome.
Message 10 of 13
(9,278 Views)
