USRP Software Radio
usrp examples
I ahve installed the NI usrp driver 1.0 from the dvd which came with the bundle and updated it to 1.2....but when I try to open the modulation tool box examples it can't find some files like
ni usrp configure signal.vi
and 3 other files
I cant find the problem
(6,907 Views)
Can you verify the LabVIEW version? Only LabVIEW 32 bit is supported by the driver even if the machine/OS are 64 bit.
(6,904 Views)
It is a 64 bit version
(6,899 Views)
Accepted by petroldevil
32 bit and 64 bit LabVIEW can both be installed on the same PC and coexist without issue.
(6,897 Views)
