UVLabVIEW
NI Web Application Service on Port 8080
All,
We have an internal web server application that binds to port 8080. Our Windows server service was unable to start. After looking at the logs and using netstat -o to find the Process ID (PID), we found that NI Application Web Server service was already bound to 8080. Once I stopped the service (and changed it to Manual), our server was able to start.
Has anybody run in to problems with Labview by disabling the NI Application Web Server service?
-Shawn
(15,669 Views)
Accepted by topic author Shawnerz
The NI Application Web Server is used for deploying user made LabVIEW Web Services. You can see more information about the NI Application Web Server in the Hosting Web Services help topic.
You can also change the port used by the Application Web Server.
Milan
(15,633 Views)
Thank you very much for the info.
-Shawn
(15,609 Views)
