Unit Testing Group
Test Evaluation - What types do you often use?
You bring up a good point of timestamps and testing code that relies on timing. We moved to a TimeProvider class for time management where we needed the testability. The class either uses the built in LabVIEW primitives (the Default stategy) or a defined result (the Mock strategy). Our production code would rely on the TimeProvider object passed to it for all timing-related functionality and then we could control the exact time in our unit tests.
We had a case where needed to implement real-time clock calibration to an external device and there was a great deal of timing related code. Previously we needed a physical setup and, due to limitations in the setup, we often had "false" fails. Using the mock helped us test the timing code without worrying about actually having the external device or the correct setup conditions. The new style was more complicated but we were able to isolate a rare bug that could have occurred.
Message 11 of 20
(5,519 Views)
NZ is awesome. Believe the tourism. You should all come and live here!
Message 12 of 20
(5,519 Views)
Actually, it is - I've spent time working and playing in NZ before, and it's an amazingly beautiful place.
Copyright © 2004-2024 Christopher G. Relf. Some Rights Reserved. This posting is licensed under a Creative Commons Attribution 4.0 License.
Message 13 of 20
(5,519 Views)
I was thinking about your comment too regarding comparison of floating point when it is part of a cluster. Looking at some of my test code I have had to do the same. This is certainly an area where the way the UTF manages the comparisons makes things easier - you can deal with the cluster directly.
Message 14 of 20
(5,519 Views)
Message 15 of 20
(5,519 Views)
justin.goeres wrote:
http://i6.minus.com/i3jsx5Whee8YM.jpg
Message 16 of 20
(5,519 Views)
Sorry for the thread hijack tyk007!
Message 17 of 20
(5,519 Views)
No worries. Loving it!
Message 18 of 20
(5,519 Views)
Sweet as
I have the desperate feeling, I need to return to Aotearoa real soon
Message 19 of 20
(5,519 Views)
Hi tyk007,
Just to catch up with you on this, we had the CLA Summit in Rome this week where I presented about Assertions. I'm putting the presentation up on the CLA forum but have also attached it here as I don't think you can get onto the CLA pages.
I'm still working on updating and finishing the code, but am going to upload the latest version of it today together with some quick videos on how it works to Github - the link is in the presentation slides. There are a few differences between the video and what I now have (such as the UI doesn't automatically pop up anymore, there is a Launch Viewer function in the Advanced API Functions section - I'm thinking of getting rid of the UI as I no longer think it will be used).
Anyway, let me know if you have any questions about the code - as I said, it's full of holes and probably some bugs at the moment, but will hopefully be useful and will get better.
Cheers,
Pete H
NIUK
Message 20 of 20
(5,518 Views)
