VI Analyzer Enthusiasts Discussions
Automatically add files to task
I'm trying to make use of VI Analyser in our CI script, so the analyser is running as part of our integration testing on feature branches.
I have tried to create a generic task, where I have added the source code folder as the Top-Level item.
However, I if then create a new subVI (or even a new project) in that folder, then this VI is not analyzed.... Do I really have to remember to update the VI Script every time I create a new VI in the very same folder?
Best Regards
Alex E. Munkhaus
Certified LabVIEW Developer (CLD)
System Engineer
(4,316 Views)
Accepted by A.E.M
Hmm, seems like it is working as I would like. When running the script through LabVIEW CLI all the VIs in the folder are analysed.
Best Regards
Alex E. Munkhaus
System Engineer
(4,283 Views)
Right, if you add a folder to a VI analysis, then all the contents of that folder are analyzed. if you then add files to the folder later, those files should be analyzed by the same VI Analyzer task without need to reconfigure it. Let me know if that's not the behavior you're seeing.
(4,276 Views)
Thanks for your reply.
Yep, that is indeed how it works... Not sure what I did in the first place 😛
Best Regards
Alex E. Munkhaus
System Engineer
(4,250 Views)
