VI Analyzer Enthusiasts Discussions
Tests enabled by default
When I load a .viancfg file any (custom) test that is installed on my pc but not defined in the file is enabled by default by the VI Analyzer. This means that whenever I use a test configuration that was created by a colleague all (custom) tests that are on my pc but not on my colleagues are enabled and therefor we don't run exactly the same test. I was wondering if there is a way to change this behaviour and to disable the tests that are not defined in the .viancfg file by default?
Best Regards,
Stefan Lemmens
Intersoft Electronics
(3,450 Views)
Accepted by topic author StefanLemmens
This behavior cannot be changed. However, in VI Analyzer 2019, we changed it so that all new tests are deselected by default.
(3,432 Views)
