VI Analyzer Enthusiasts Discussions
VI Analyzer execution time is different when run as a batch vs one at a time
I need to create a single report for each vi that is run through the analysis.  I have looked at a couple of different ways of performing this but all are significantly slower than using the batch method.  I have created and attached a VI that compares the methods to run the analysis on a folder of vi's.  To simplify the comparison I did not include the report generation as this does not have a significant impact on timing.  I can only assume that the analysis is so much slower when run one on one vi at a time due to allocating memory for the test results.  I would like to confirm if that is indeed what is going on, or is there another method that I can generate a single report for each vi?  Is it possible in a future release to have an option to create a separate report for each vi when run in a batch?
Message 1 of 1
(2,464 Views)
