VI Analyzer Enthusiasts Discussions
VI Analyzer Select VIs shows multiple duplicate folders in the Items to Analyze control
Hi there,
I am using LabVIEW 2017 SP1 f4 32-bit (version required for a specific client).
I created a custom VI Analyzer configuration for a project.
I added the top level item, and then went in and excluded a bunch of files.
I saved the configuration file.
Then later, I opened the configuration file again, and the Items to Analyze control shows multiple duplicate folders as per below.  Notice how there are duplicates of each folder except one?
When I expand the first instance of "Viscosity" - I see the exclusions I made.  When I expand the second Viscosity, there are no exclusions.
Has anyone else experienced this?
Perhaps it was resolved in LabVIEW 2018?
Christopher Farmer
Certified LabVIEW Architect and LabVIEW Champion
DQMH Trusted Advisor
https://wiredinsoftware.com.au
(3,556 Views)
Yes, I believe this issue was fixed in a recent LabVIEW version, but I don't remember if it was 2018, 2019 or 2020. Let me know if you need me to track down the specific version that has the fix.
(3,519 Views)
Thanks Darren.
I worked around it by changing my top level item one level down.  ie.  The top level folder is now "Libraries".  This works.
Christopher Farmer
(3,501 Views)
