VXI and VME
HP E2749A VXI fibre channel interface
Currently we are using three HP E2749A fibre channel interface cards. Unfortunately, this product is no longer supported by Agilent.
We record 24 channels of 16bit digitized data (160k samples/sec/channel) to a Ciprico RAID via a fibre controlled arbitrated loop.
I am presently investigating options to refurbish this system. The Controller used in the VXI chassis is a HP E1498A/V743
If you have a product which may fit this use or need information before responding please replay as soon as possible.
(6,303 Views)
National Instruments does not have a fibre channel interface card or a product for that type of application. Good luck in your search!
(6,303 Views)
