VXI and VME
Multi-Mainframe with VXI-MXI-2 on VxWorks problem
I have two VXI Mainframes and use two VXI-MXI-2 boards connected. My OS is VxWorks 5.5 running in VXIpc874B. After running resman, it must show borads in two mainframes. but it usually show boards in first mainframe. I try to run resman several times. Sometimes,  the boards of second mainframe apear again. When the boards of second mainframe disapear, the second VXI-MAI-2 disapear too.
How do I configure my system?
Message 1 of 16
(12,097 Views)
http://sine.ni.com/kb/main/p/sb/navsRel?q=NI%20VXI-MXI-2
http://digital.ni.com/public.nsf/allkb/F09CB807E492FAE8852563D500648EAC
Try above first.
Also you can contact Taiwan local branch directly.
NITW AE
Message 2 of 16
(12,087 Views)
Hi Fatty,
Thanks for your reply.
I want to clearly my problem. My problem is after vxworks boot up and run the resman, I can only saw the first mainframe's VXI-MXI-2 and my system does not hung up. it works perfact. If I run resman again(maybe serval times), I can find the second VXI-MXI-2 which is in the second mainframe. That's my problem.
I want to simplify my problem. May someone can help me to check the hardware setting first. I will list my setting in seprate reply.
Message 3 of 16
(12,073 Views)
MyController(VXIpc874) is in Mainframe 1 and LA is 0
        1st VXI-MXI-2 in Mainframe 1      2ed VXI-MXI-2 in Mainframe 2
LA      1                                                128
S2     Off                                              Off                                        50 Terminal for External Trigger Input
S3     Out                                             Out                                       SMB CLK10 Direction
S4     Off                                               Off                                        20 Terminal for SMB CLK10
S5     Inverted                                       Inverted                                SMB CLK10 Output Polarity
S7    Drive CLK10 out MXIbus             Receive CLK10 from MXIbus
S8     No                                              No                                        VXI-MXI to left
S9     No                                              No                                        VXI-MXI to right
W2    Auto                                           Auto
W3    From onboard oscillator            From MXIbus
U35 - 1   Yes                                       Yes                                       Terminal MXIbus
U35 - 2   Yes                                       Yes                                       Automatic MXIbus Terminal
U35 - 3    No                                        No                                        Change Factory Configuration
U35 - 4    No                                       No                                         Restore Factory Configuration
I referance these configure from the VXI-MXI-2 User Manual. I am not sure if lost some setting.
Another question. Is any sequence to power on the mainframe? Does first mainframe need to power on first or second one? Or never mind this.
Thanks if anyone can check my problem.
Message 4 of 16
(12,072 Views)
Will you send your information to support.taiwan@ni.com.
Maybe we can arrange on-site support.
NITW AE
Message 5 of 16
(12,037 Views)
Ok, Thanks your replay
Message 6 of 16
(12,027 Views)
Can I know how are you running resman? Are you using a host PC with Windows?  Are you configuring your system visa Remote Systems Measurement and Automation software?
If you are, would you take a screenshot showing when your system can see the first mainframe's VXI-MXI-2 but not the second?  Also, take a screenshot when the second VXI-MXI-2 appears appropriately.
Thank you very much,
NITW AE
Message 7 of 16
(11,995 Views)
Sorry! I am using VxWorks 5.5 as my OS. And I can not capture the screen for you. Now my solution is do below function after I boot up. I just call resman() until I find my second VXI-MXI-2 module. But I think that is not a good ideal.
long StartupVXIMXI2()
    char szExper[] = "VXI?*INSTR";
    char szMF2Name[] = "VXI0::128::INSTR";
    ViChar instrDesc[MAX_INST_LIST][255];
    ViFindList listInstr;
 ViUInt32 nInstCnt;
    ViStatus status;
    ViSession inst;
    char szModuleName[255];
    unsigned short int nSlot;
    long nRet = -1, bFindMF2 = 0;
 do {
        taskDelay(10);
  logMsg("L%d, Searching instrument ...\n", _module_line());
     if( status = viFindRsrc(instGetResourceManager(), szExper, &listInstr, &nInstCnt, instrDesc[0]), status < VI_SUCCESS ) {
         printf("ERR %d, viFindRsrc('%s') fail\n", nRet = _module_error_code(), szExper);
   break;
      logMsg("L%d, %d instruments found\n", _module_line(), nInstCnt);
     if( nInstCnt ) {
   printf("==========================================\n");
         for(int i=0; i<nInstCnt && i<MAX_INST_LIST; i++) {
                nSlot = -1;
                if( status = viOpen(instGetResourceManager(), instrDesc[i], VI_NULL, VI_NULL, &inst), status != VI_SUCCESS) {
                    logMsg("E%d, Open instrument %s fail\n", _module_line(), instrDesc[i]);
                else {
                    if( status = viGetAttribute(inst, VI_ATTR_MODEL_CODE, &nSlot), status != VI_SUCCESS) {
                    viClose(inst);
                if( strcmp(szMF2Name, instrDesc[i]) == 0)
                    bFindMF2 = 1;
             logMsg("L%d, %d.%s MODEL %u\n", _module_line(), i+1, instrDesc[i], nSlot);
             status = viFindNext(listInstr, instrDesc[i+1]);
            if(!bFindMF2) {
                taskDelay(10);
                instReleaseResourceManager();
                taskDelay(10);
                resman();
                continue;
   nRet = 1;
 } while(!bFindMF2);
    return nRet;
Message 8 of 16
(11,987 Views)
Hello Zodicx,
On the Tornado development environment, I would like to see the differences when only one of the VXI devices is detected. Can you let me know what the sysfail lights and sys lights are during these times?
NITW AE
Message 9 of 16
(11,967 Views)
Hello Zodicx,
I hope to get more information from you.  Can you provide me the log Resman creates along with the information from the Sys and Sysfail lights.
Also have you checked the mxi-2 cables for any bent pins?
NITW AE
Message Edited by ForwardC on 02-19-2009 07:18 PM
Message 10 of 16
(11,963 Views)
