VXI and VME
Multi-Mainframe with VXI-MXI-2 on VxWorks problem
I am sorry for reply so late. I an busy few weeks ago.
I am glad to get more information to you. but i don't know how to dump the vxworks message. all message showing in the monitor.
I have two MXI2 cable. I have change it to test. but it is the same.
My cable part no are 182802A-004 and 182801A-002
Message 11 of 16
(5,864 Views)
Hi ForwardC,
I got the log from telnet. I post it in attachment file. You can see I run resman several time. At the last one, all the instrument in the second mainframe was found.
Message 12 of 16
(5,850 Views)
Hello Zodicx,
It could be possible that the secondary chassis is not able to respond fast enough. We would like to see if the system will recognize items/modules after it fails to pick up the VXI-MXI-2 card. Another experiment we can perform is placing the system in star configuration and check the results for this. Let me know how this goes. Thank you.
Thanks!
NITW AE
Message 13 of 16
(5,820 Views)
Hello Zodicx,
Have you gotten a chance to try the star configuration I mentioned above?
"It could be possible that the secondary chassis is not able to respond fast enough. We would like to see if the system will recognize items/modules after it fails to pick up the VXI-MXI-2 card. Another experiment we can perform is placing the system in star configuration and check the results for this. Let me know how this goes. Thank you. "
Please have it a try. Thanks!
NITW AE
Message 14 of 16
(5,792 Views)
Hi ForwardC,
I am not sure about the star configuration. My system are only two mainframes and connected with two VXI-MXI-2.
I removed others modules and opwer on again. There are only two VXI-MXI-2 and one VXIpc874. The result is the same.
I dump my configure from vxiedit.
please tell me if any wrong. Thanks
Message 15 of 16
(5,778 Views)
Excuse me!
Is any comment this week?
Message 16 of 16
(5,710 Views)
