VeriStand
AIT429 Custom device error -2
The meaning of error is: "Could not open AIT Board with SN: 0 on "local". Ressource not found for serial number". What must be done to set the Serial Number of the Board. This error occurs while deploying the System Definition File on the target (VeriStand).Thanks.
(6,193 Views)
Which version of the custom device did you use?
Did you download it on this link?
https://decibel.ni.com/content/docs/DOC-18466
What is the target (windows, PXI, cRIO)?
Regards
Samuel G. | GEMESIS
Certified LabVIEW Architect
Certified TestStand Developer
GEMESIS.EU
(6,171 Views)
I solved my problem by setting the serial number of the Arinc Card at VeriStand level in the field "Board Serial".
(6,158 Views)
Thanks for the feedback
Samuel G. | GEMESIS
GEMESIS.EU
(6,146 Views)
