VeriStand
Custom Device_RT Rebooted
HI all:
I have a strange problem about using Custom Device in VeriStand. After i developed a custom device (Inline HW)according to the methods on"niveristand_cd_dev_guide.pdf ", I builded it to the Default Directiory(Common Document..),and then added it to my System Definition(without any other setting). But when I deployed it to the RT Target, the message showen as the attachment,and the RT rebooted then into “Safe mode” ——System Error
I have also took anther test: Even I developed a Custom Device based on the Template without any added code, then added to my System Definition, the RT Target also encountered the same problem. I am very puzzled and need your help Strongly, Any help will be greatly appreciated.
My Sytem Configuraton is as following:
NI PXI 8106 RT Controller
VeriStand 2011 SP1
LabVIEW 2011 SP1
LV Real Time 2011SP1
Window XP
Message 1 of 1
(5,726 Views)
