VeriStand
Apply parameter values from file at initialization doesn't works
Hi, When I use the feature "Apply parameter values from file at initialization",I found it doesn't work as expected . I add two compiled  simulink model which called model1 and model2 and creat a .txt file in which I add two parameter form this two models, i changed the initial value of this two parameter and then use "Apply parameter values from file at initialization", after i deploy the system definition file to the target  i found only one parameter' initial value  form model1 was changed and the other parameter's initial value from model2  was not changed. I don't konw why, could you help me? Thanks!
By the way, the version of my NI Veristand is 2013, and I inported all parameters of the two models when i inported parameters.
Message 1 of 1
(3,102 Views)
