VeriStand
[BUG] Exporting a Simulink model to Veristand, that uses legacy_code, with code containing N-dimensional variables
Steps successfully completed :
- Built a model from Simulink and exported it into Verisdand, with the expected behavior.
- Same, but with C code re-use using the legacy_code tool
Current objective :
- Same, with the additionnal condition that my legacy code must allow the output of :
   * Variables with two dimensions
   * Array of structures.
Bug description :
While the simulation runs fine, the last step of building the model into a Veristand usable model fails under said conditions. The generated code gives the follwing message for multidimentional variables and 'sometimes' arrays of structures : "too many initializers". This issue is confirmed because when I reduce the dimentionnality of my variables of reduce the number of elements in the structure to 1, then there is no error.
Configuration :
- MATLAB 2015b
- NIVS 2015 SP1
Please let me know if you have any idea or suggestion on which approach I should try to solve this issue.
(4,513 Views)
Steps to reproduce :
- Create a Simulink model and use a legacy_code block
- Wrap a piece of code that outputs a structure with a multidimentional variable
- Build for Veristand using the NIVS Builder
- The error message 'too many initializers' shows up in the build log
(4,492 Views)
Steps to reproduce the bug
1. Execute the script "PR_1_INIT.m"
      -> Buses are initiliazed in the workspace
2. Execute the script "PR_2_GenLegacyCode.m"
      -> The legacy_code code is generated
3. Open the model "PR_3_Model.slx"
4. Run the simulation
      -> No error.
5. Build
      -> "PR_3_Model_data.c(167) : error C2078: too many initializers"
When going to the line associated to the error in the generated code, we see that it is due to a bad parallelisation of the 2 dimensionnal structure.
By changing the dimensions of the variables so that they are 1-D, then there is no error and the model build fine.
To do this, comment / uncomment lines :
- 7 and 10 of PR_1_INIT.m
- 5 and 8 of PR_legacy_code.h
Then run steps 1 to 5 again.
(4,447 Views)
My interpretation of the observed behavior: the code generation NIVS plugin processes the declaration of arrays in a way that MyStruct StructTab[2][3] and MyStruct StructTab[2*3] are seen are identical.
This is observable in the  generated code because if we suppose that MyStruct is a type containing 5 integers, then we see:
StructTab = {{0,0,0,0,0},{0,0,0,0,0},{0,0,0,0,0},{0,0,0,0,0},{0,0,0,0,0},{0,0,0,0,0}};
while it should be:
StructTab = {{{0,0,0,0,0},{0,0,0,0,0},{0,0,0,0,0}},{{0,0,0,0,0},{0,0,0,0,0},{0,0,0,0,0}}};
The way I see it, the solution could be to find a trick -which I don't know how at the moment- in the way I declare variables in Simulink.
Additionnal info: I'm using .net4.0 because .net4.4 induces a linking error with my configuration Matlab2015b and NIVeriStand2015SP1.
(4,424 Views)
About the "and sometimes user defined structures of structures" that I mention in the top post, I reproduced that behavior on my original project but I'm unable to locate the exact point that triggers the error. As far as I understand, the same error message should appear in the sample project I posted due to the SubStruct1 and SubStruct2 inside of Struct, even when DIMENSION is set to 1.
(4,410 Views)
Thank you for the detailed report, Franck. I've documented the bug for further investigation. Please note that I'm unable to provide you with a guaranteed fix date. Rest assured that your detailed steps will expedite the investigation.
Nestor
(4,368 Views)
Thank you Nestor,
I have bypassed the issue for now by making all the incriminated variables of the shape a(M,N) into a(M*N).
Also the issue mentioned in my previous post (about multi element structure) was a design induced bug by me. So the only bug remaining is the one described in the small project I posted.
(4,361 Views)
