VeriStand
Unable to send CAN messages if the model command is an array.
Configuration: VeriStand 2015 SP1 with CAN card PXI 8512
History: I created a model using Simulink, is a set of simple outputs that can be of value 0 or 1.
When I build my model so that it outputs a single signal that I then set in VeriStand as the "Trigger channel (non zero)" for my Event triggered Outgoing message on the CAN BUS, then the message is sent, at the moments where the model output signal is equal to one.
Issue: When I build my model in order to output several command signals in an array -let's say an array with 3 elements- in order to command several messages, then the message is not sent anymore. When I use a scope to watch the signal coming from the model, it doesn't even display anymore -while it did with the single output model-.
Thank you for your help.
Message 1 of 1
(2,619 Views)
