VeriStand
CAN I read data from a Excel file, and assign the data values to Veristand Channel?
The real time sequence runs in the Veristand engine. But in the real time sequence (created by Stimulus profile editor), you can not read data from a file (for example Excel file or Word file) and assign the data value to channels.  Is it possible to read the data from a file in the Veristand engine, and assign the data value to channels (not by mapping)? Thanks!
Message 1 of 11
(558 Views)
Perhaps you are looking for this VeriStand User Manual: Using CSV Files as Real-Time Sequences build in feature of stimulus profile.
CLA, CTA, CLED
Message 2 of 11
(543 Views)
Thanks for help. I know CSV files can be used as real-time sequences. But this is not I want.
Because we have developed a lot of applications that the load data was saved in Excel file (xlsx file). So I'm looking for a solution to read the data from Excel file in the Veristand Engine.
Message 3 of 11
(513 Views)
More advanced functionality, that includes xlxs file parsing, channel mappings, execution flow control (channel enable, trigger, ... ) signal mappings, etc ...
That all sounds like a good candidate to consider development of dedicated VeriStand Custom Device (aka custom plugin which extends NIVS for functionality that you need).
CLA, CTA, CLED
Message 4 of 11
(504 Views)
If you are open to using Labview, you can read in your excel data and use the VeriStand API's to write array (VS channel, data) to Veristand.
Message 5 of 11
(494 Views)
Hello:
What is aka custom plugin, can you share some information about this plugin? Thanks!
Message 6 of 11
(379 Views)
Hello:
Can you share some information about aka custom plugin? Thanks!
Message 7 of 11
(376 Views)
Hello: Can you share some information about aka custom plugin? Thanks!
Message 8 of 11
(372 Views)
Hello, Can you share some information about aka custom plugin? thanks!
Message 9 of 11
(370 Views)
Hello:
But is the LabVIEW VI run in veristand engine? Thanks!
Message 10 of 11
(357 Views)
