VeriStand
Make a can message sending cycle adjustable in Veristand with multiplexer
I need to configure the can message sending cycle in my Veristand project while the can message was defined as multiplexer one.
For example,In situation A ,this message should be configured for 100ms cyclic transmission.In situation B,this message should be configured for 1000ms cyclic transmission.
Is there any solution for this? It will be helpful for me if any advice could be given.
Thanks!
Message 1 of 1
(150 Views)
