VeriStand
Calculated Channel FORMULA is frustrating
Why is there no means by which to type in a Formula when creating a Calculated Channel? The user is forced to use the supplied virtual keyboard and if you made a mistake 10 characters back, you can't place the cursor at the type, you're only choice is to delete the last 10 characters one at a time. A very time consuming and frustrating way to input anything but the most basic formula.
(2,701 Views)
I totally agree.  You have to really plan out how you are going to type it before you start.  For complex calculations I usually just make a VI and convert it to a model to import.  You should post this on the VeriStand Idea Exchange , I would vote for it.
(2,676 Views)
