VeriStand
Calculated channels display/sort order
Is there a way to display the Calculated Channels in System Explorer in anything other than the evaluation order? I'd like to sort by name due to the large number of calculated channels that I have.
Thanks.
(5,977 Views)
Hello hyog,
Currently the evaluation order is the only order they will appear. Please submit this on the NI VeriStand Idea Exchange, like this post talking about improving the usability for changing the order of Calculated Channels, but differentiating display order versus execution order.
Thank you,
Deborah Y.
Deborah Burke
NI Hardware and Drivers Product Manager
Certified LabVIEW Architect
(5,963 Views)
I've found an interim workaround. I noticed that if I don't expand the Calculated Channels folder and instead use the find tool to find a channel, then when I go to that found channel, System Explorer will list the channels in alphabetical order instead!
(5,757 Views)
