VeriStand
INERTIA Add-on Test Editor Cannot Log Aliases
I am using the INERTIA  Add-on for VeriStand and I noticed that when I try to add channels in the Data Logging dialog of the Test Editor, the Aliases that I have set up in the VS System Definition tool are not available to choose from.  Is there an update to this tool that will add the filter for the Aliases to the Select Channel Dialog?
(5,845 Views)
Hi Aaron,
The INERTIA Add-on for Veristand is developed by Wineman Technologies. Since we don't have access to the source code for the Test Editor custom workspace tool I would recommend contacting Wineman (support@winemantech.com) to see if they can add this functionality in the next update for this add on.
Sev K.
Senior Systems R&D Engineer | Wireless | CLA
(5,818 Views)
