VeriStand
Can not running project in VeriStand 2017
I'm now beginning to learn how to design a real-time test system with LabVIEW 2017 and VeriStand 2017. When I built a simple project to run on Window 10 target PC, it could not running and had a error message as below.
Please let me know what I should do to solve this problem! Thanks a lot!
This error message like this:
VeriStand Engine.lvlib:VeriStand Engine.vi
Missing subVI DAQmx Configure Logging (TDMS).vi in VI DAQ Waveform Engine.lvlib:Set Task Logging.vi.
Missing subVI DAQmx Control Task.vi in VI DAQ Waveform Engine.lvlib:Initialize DAQ Waveform Data.vi.
Missing subVI DAQmx Reference Trigger (Digital Edge).vi in VI DAQ Waveform Engine.lvlib:Set Task Triggers.vi.
Missing subVI DAQmx Reference Trigger (Analog Window).vi in VI DAQ Waveform Engine.lvlib:Set Task Triggers.vi.
Missing subVI DAQmx Reference Trigger (Analog Edge).vi in VI DAQ Waveform Engine.lvlib:Set Task Triggers.vi.
Missing subVI DAQmx Start Trigger (Digital Edge).vi in VI DAQ Waveform Engine.lvlib:Set Task Triggers.vi.
Missing subVI DAQmx Start Trigger (Analog Window).vi in VI DAQ Waveform Engine.lvlib:Set Task Triggers.vi.
Missing subVI DAQmx Start Trigger (Analog Edge).vi in VI DAQ Waveform Engine.lvlib:Set Task Triggers.vi.
Missing subVI DAQmx Timing (Sample Clock).vi in VI DAQ Waveform Engine.lvlib:Set Task Timing.vi.
Missing subVI DAQmx Control Task.vi in VI DAQ Engine.lvlib:DAQ Start Tasks.vi.
Missing subVI DAQmx Control Task.vi in VI DAQ Engine.lvlib:Create Virtual Channels CTR SectionType.vi.
Missing subVI DAQmx Control Task.vi in VI DAQ Engine.lvlib:Create Virtual Channels CTR.vi.
Missing subVI DAQmx Create Channel (CI-Position-Linear Encoder).vi in VI DAQ Engine.lvlib:Create Virtual Channels CTR.vi.
Missing subVI DAQmx Create Channel (CI-Count Edges).vi in VI DAQ Engine.lvlib:Create Virtual Channels CTR.vi.
Missing subVI DAQmx Control Task.vi in VI DAQ Engine.lvlib:DIDO Set Timing and Source.vi.
Missing subVI DAQmx Control Task.vi in VI DAQ Engine.lvlib:AIAO DAQ Master Set Timing and Source.vi.
Missing subVI DAQmx Start Trigger (Digital Edge).vi in VI DAQ Engine.lvlib:AIAO DAQ Master Set Timing and Source.vi.
Missing subVI DAQmx Timing (Sample Clock).vi in VI DAQ Engine.lvlib:AIAO DAQ Master Set Timing and Source.vi.
Missing subVI DAQmx Control Task.vi in VI DAQ Engine.lvlib:AIAO None Set Timing and Source.vi.
Missing subVI DAQmx Timing (Sample Clock).vi in VI DAQ Engine.lvlib:AIAO None Set Timing and Source.vi.
Missing subVI DAQmx Create Channel (AI-Current-Basic).vi in VI DAQ Engine.lvlib:Create Virtual Channels AIAOInternal.vi.
Missing subVI DAQmx Create Channel (AI-Voltage-Basic).vi in VI DAQ Engine.lvlib:Create Virtual Channels AIAOInternal.vi.
Missing subVI DAQmx Create Timing Source (Signal From Task).vi in VI NI VeriStand Engine.lvlib:Initialize Engine Timing Source Data.vi.
Missing subVI DAQmx Create Timing Source (Control Loop From Task).vi in VI NI VeriStand Engine.lvlib:Initialize Engine Timing Source Data.vi.
Missing subVI DAQmx Close External Calibration.vi in VI InSitu Calibrations.lvlib:Run InSitu Calibrations.vi.
Missing subVI DAQmx Create Channel (AI-Voltage-Basic).vi in VI InSitu Calibrations.lvlib:Run InSitu Calibrations.vi.
• Unloading System Definition file...
(3,447 Views)
Accepted by topic author ntsinhtb11
It looks that you haven't installed DAQmx driver after you installed 2017 software.
Please try to install DAQmx 17.0.
Certified LabVIEW Developer
GCentral
(3,415 Views)
Pignite, thank you very much for your help! I have set up the DAQmx 17.0 and the System Definition file have successfully deployed. But after that, the VeriStand.UIManager  of the VeriStand 2017 encountered a problem and must exit, so I could not run my model. The (.vi) model and (.lvmodel) model that were built in LabVIEW 2017 before for establishing the project by VeriStand 2017. My Window 10 Laptop is set up with three LabVIEW versions (2015, 2016 and 2017) and three VeriStand versions (2015SP1, 2016 and 2017) that need for our studying. After that I have tried to rebuild the model and the corresponding project with LabVIEW 2016-VeriStand 2016 and it ran well. I do not know which caused the problem. Please show me the solution. Thank you!
The attach file is the error.
(3,386 Views)
Im really glad to hear that your problem has been resolved.
As my understand, UI Manager is very useful software but occasionally crash with unexpected cause.
How about using Workspace page instead of the software?
To tell the truth, my UI Manager also crash occasionally Smiley Frustrated
GCentral
(3,380 Views)
