I have built a project where a signal sent by a model is driving a CAN message transmission by setting the
"Target > Controller NI 8840 > Hardware > Chassis > NI-XNET > CAN > CAN1 Outgoing > MyMessage"
In the following configuration :
Transmission trigger > Transmit trigger : Trigger Channel (non-zero)
And setting "Trigger Channel" to the signal of the model.
I'm using a PXI 8512, with NIVS 2015 SP1 and a Controller NI 8840.
When using a signal that commands the message transmission once every N = 10 time slots then the transmission doesn't happen. But it does happen when I use N = 11 as illustrated.
Here are 2 scope captures of the issue at hand :
When using this signal to drive the transmission then there is no transmission.
For N = 11 then the transmission happens as expected.
The following time slot counts have been tested :
OK : 3, 4, 8, 9, 11, 19, 21, 31
KO : 10, 20, 30
This is an issue because my actual project needs to be sending with time slots that are a multiple of 10 -it doesn't work at the moment.
I attach all the required files to reproduce the problem with this post -with both prebuilt models dlls and editable Simulink model.
