VeriStand
Dialog to select a channel
Hi
I want to create a custom device which will allow me to select channels from the system explorer. I found NI Veristand Add-on - Channel Select Dialog (http://zone.ni.com/devzone/cda/epd/p/id/6266) . That's exactly what i need. I downloaded this add on and tried to call the vi from the Main page of the custom device.
The first thing is this vi need NIVS.System Definition Root .To get this i wrote the code attached.
I don't thinkif it's really working cause when i call the channel_select_dialog.vi  the treeview on which i am supposed to select the channel is empty.
So what is the good method to get the System definition  Root ? Is it possible to call the channel_select_dialog.vi from a custom device ? or is it reserved to Custom Workspace Objects??
(7,022 Views)
See the waveform custom device shipping example (in 2012). It has a channel selection dialog you can copy.
Stephen B
(7,004 Views)
Hi Stephen
I downloaded the add on  "Waveform Data Logger Custom Device" from here :
https://decibel.ni.com/content/docs/DOC-29957
Unfortunately the source code is not provided, and when i try to open the Main page from the llb, i can't access to the diagramm block. Any idea ?
(6,998 Views)
At this time we have not decided to release the source code for that download.
instead, look at the shipping example I mentioned before
Stephen B
(6,985 Views)
Hi stephen
Can you tell me where i can find this example, i didn't found any waveform custom device example in VS 2012... that's why i downloaded the Waveform data logger ...
Thanks...
(6,891 Views)
It is here on my computer:
C:\Program Files (x86)\National Instruments\LabVIEW 2012\examples\NI Veristand\Custom Devices\Waveform Analysis and Generation
Stephen B
(6,881 Views)
One input is required:
  • NIVS.System Definition Root - This is a reference to the system definition you wish to browse. If creating a workspace tool, service or object, you can right click this input and select Create -> Control to add this control to your top level workspace tool/service/object's front panel. NI VeriStand will automatically set this control value when your tool/service/object is run, so then just wire this control value to the subVI.
(3,702 Views)
