VeriStand
Connection and deployment problems with PXI although PXI is found in NI MAX
After upgrading my PXI Real-Time Sytem (RTS) from VeriStand 2011 to VeriStand 2019, I am not able to deploy my program from VeriStand 2019 to the upgraded RTS. The error message I am encountering during the deployment-state in VeriStand 2019 is, that there is something wrong with “WebDAV”. The background is, that during the deployment-state there is a pop-up window named “WebDAV Login”, which requires a admin-username and a password, which I am entering but VeriStand is denying it.
To resolve this issue I have tried to follow the instructions stated on this website: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019PlESAU&l=de-DE, but there was a again an error message, which is denying the username and password.
Hence, it seems that there is a connection-error with my PXI, but the strange thing is that it appears in the NI MAX program and there I am able to logon by entering username and password.
Another thing which I am recognized is, that I am not able to get a connection with the webserver of my PXI, while trying to reach it with my Chrome or Internet-Explorer browser. Always there is a message appearing to install Microsoft Silverlight, but this add-on is already activated in my browser.
(2,582 Views)
Hello, have you already updated NI software in PXI controller? For example, NI driver, NI VeriStand engine, etc...
The version of those software should be same on Windows.
I guess it's caused by version compatibility problem.
Certified LabVIEW Developer
GCentral
(2,534 Views)
All the stated problems arose also with an updated PXI-System. Hence the VeriStand SW on the host PC was updated and the PXI. Now I have even reset the whole PXI in order to counteract some upgrading issues and I have set up my system from "scratch", hence from a formatted PXI system but the stated problems remain.
(2,515 Views)
Any security software is blocking NI VeriStand...? Why don't you check firewall?
GCentral
(2,487 Views)
Good hint but the solution to solve my problem consisted of two steps:
1. Installation of right VeriStand Version together with the correct packages and the right X-Net Database (related to my VeriStand-Project) installed on the real-time-systems.
2. Correct router setup with right port-forwarding adjustments inside my router. I could find the ports which VeriStand and the MAX uses with the tool "Wireshark".
(2,356 Views)
