VeriStand
Custom Device Version in the updated XML not getting updated in the get Custom Device Version Module.
Hi All,
I am using NI LabVIEW 2023Q1 and VeriStand2013Q1, I have created a custom device and added as a part of system Explorer -
<Version>1.0.0</Version>
Now I have Modified the custom device - <Version>2.0.0</Version>
I have replaced the custom device in the respective VeriStand folder and Restarted the VeriStand expecting that my MainPage display the Version as 2.0.0 but it still shows 1.0.0 but If I delete and add/add as another instance it shows as 2.0.0.
Is there something to be enabled on Load or is this the expected behaviour?
(379 Views)
Accepted by topic author PalanivelThiruvenkadam
Solved! we need to use SysDef.UpdateCDVersionFromXML.vi  "ActionVIOnLoad"
(348 Views)
