VeriStand
Dynamically set channel reference of realtime sequence
Hi There,
I would like to create a generic real time sequence that can be used to ramp various channels inside my system without having to hardcode a new real time sequence for every possible channel I might want to ramp. Is there a way to call this sequence from TestStand using the ASAM XIL steps that would allow me to have an input parameter that states what channel I would like to ramp inside the RT sequence?
(1,427 Views)
Did you get any solution for this ? Am also searching to implement ASAM XIL steps with expression as channel inputs.
(932 Views)
