VeriStand
On NI VeriStand GUI CAN data reading issue
Hi all, I am using the NI Veristand version 2017. I am facing some CAN data issues on the HIL system. While sending any signal data on the CAN bus from one node to another node, I can see my signal data is on the CAN bus(on Bus monitor), and it's varying ( I don't have any issue with varying data). But on the VeriStand GUI screen, I see only that signal assigns initial data(value assigned in .dbc file). I checked everything, changed the transceiver and receiver nodes in the .dbc file but facing the same issue. If anyone has any idea about it please help me.
(902 Views)
Can you provide some screenshots to explain what you meant by "signal assigns initial data(value assigned in .dbc file)"?
https://tmesystems.net/
(869 Views)
Here on NI Xnet database, whichever the default value I assign only this value is populated on NI Veristand GUI irrespective the data present on CAN bus. I need CAN bus data on VeriStand GUI screen.
(851 Views)
