VeriStand
Erratic Error 66 while deploying on RT Computer
I am having a very annoying problem with my Veristand 2014 project deploiement. The project use a lot of custom device driver (RTD card, industrial programmable DIO, power supply, ....)
Some times when I modify a project I am not able to deploy it and I keep getting the error 66 message and my other projects that were working before just don't want to deploy too.
And after some (a lot of) tries it starts working again without me doing anything except maybe restart my complete bench if it was the evening.
Does anyone else have the same problem and is there a solution to it.
Sincerely
Benjamin
(3,926 Views)
The error 66 has different possible root.
Can yopu provide all the mesage of error ?
In ypur case, it seems the problem comes from the deploiement.
Can you check the parameter described as bellow ?
http://digital.ni.com/public.nsf/allkb/E94F4699B7FB82E086256B6E007B0AB3
Best Regards,
Guillaume D
(3,878 Views)
Here is one complete error message I just change my project name to toto
• Start Date: 07/06/2016 11:40
• Loading System Definition file: C:\Users\Public\Documents\National Instruments\NI VeriStand 2014\Projects\toto\toto.nivssdf
• Preparing to deploy the System Definition to the targets...
• Compiling the System Definition file...
• Initializing TCP subsystem...
• Starting TCP Loops...
• Connection established with target Controller.
• Sending reset command to all targets...
• Preparing to deploy files to the targets...
• Starting download for target Controller...
• Opening FTP session to IP 169.254.200.135...
• Processing Action on Deploy VIs...
• Gathering target dependency files...
• Downloading toto_Controller.nivsdat [3657 kB] (file 1 of 3)
• Downloading CalibrationData.nivscal [0 kB] (file 2 of 3)
• Downloading toto_Controller.nivsparam [0 kB] (file 3 of 3)
• Closing FTP session...
• Files successfully deployed to the targets.
• Starting deployment group 1...
The VeriStand Gateway encountered an error while deploying the System Definition file.
Details:
Error 66 occurred at Project Window.lvlib: Project Window.vi >> Project Window.lvlib:Command Loop.vi >> NI_VS Workspace ExecutionAPI.lvlib:NI VeriStand - Connect to System.vi
Possible reason(s):
LabVIEW: La connexion réseau a été fermée par l'autre partie. Si vous utilisez la fonction Ouvrir une référence de VI sur une connexion au VI Serveur distante, vérifiez que l'ordinateur a les autorisations d'accès nécessaires en sélectionnant Outils>>Options>>VI Serveur du côté serveur.
NI VeriStand: ??? dans Server TCP Interface.lvlib:TCP Send Loop.vi:3000002->Server TCP Interface.lvlib:TCP Connection Manager.vi:7430001
I will check parameters but could it work sometimes with an erroneous configuration. As I understand these parameters VeriStand shouldn't be able to run even once if they aren't right as it wouldn't be able to deploy anything.
(3,873 Views)
